DC Motor Block
A project log for Barnabas Robotics ArduBlock Upgrade
An upgrade for ArduBlock
NateNate 08/02/2019 at 02:080 Comments
ardublock.xml
- add block genus
The block genus "initializes" the block. It determines the block's physical form and what it can connect to.
The four options, CW, CCW, ISTOP and RSTOP are all their own block as well which must be added.
- add block family
Since CW, CCW, ISTOP and RSTOP are related options, they must be placed in the same block family. This allows them to be included together in the same drop down menu as shown above.
- add block genus to block drawer
The blocks should be added to the corresponding block drawer. This is the "folder" the blocks are located within arduBlock.
block-mapping.properties
- connect block genus to path of block java file
ardublock.properties
- add block label
bg.CW=CW
bg.CCW=CCW
bg.IStop=ISTOP
bg.RStop=RSTOP
- add block description
bg.DCMotor.description=DC motor control
bg.CW.description=Turns motor clockwise
bg.CCW.description=Turns motor counter-clockwise
bg.IStop.description=Instantly stops motor
bg.RStop.description=Gradually stops motor
This is the java file: DCMotorBlock.java
package com.ardublock.translator.block;
import com.ardublock.translator.Translator;
import com.ardublock.translator.block.exception.SocketNullException;
import com.ardublock.translator.block.exception.SubroutineNotDeclaredException;
public class DCMotorBlock extends TranslatorBlock
    public DCMotorBlock(Long blockId, Translator translator, String codePrefix,    String codeSuffix, String label)
        super(blockId, translator, codePrefix, codeSuffix, label);
  @Override
    public String toCode() throws SocketNullException, SubroutineNotDeclaredException
      TranslatorBlock pinBlock0 = this.getRequiredTranslatorBlockAtSocket(0);
      NumberBlock pinNumberBlock0 = (NumberBlock)pinBlock0;
      String pinNumber0 = pinNumberBlock0.toCode();
      translator.addSetupCommand("pinMode(" + pinNumber0 + ", OUTPUT);");
      TranslatorBlock pinBlock1 = this.getRequiredTranslatorBlockAtSocket(1);
      NumberBlock pinNumberBlock1 = (NumberBlock)pinBlock1;
      String pinNumber1 = pinNumberBlock1.toCode();
      translator.addSetupCommand("pinMode(" + pinNumber1 + ", OUTPUT);");
  		TranslatorBlock rotation = this.getRequiredTranslatorBlockAtSocket(2);
      String pinControl = rotation.toCode();
      String ret;
      if (pinControl.equals("CW") == true)
        ret = "\tdigitalWrite(" + pinBlock0.toCode() + ", HIGH); \n\tdigitalWrite(" + pinBlock1.toCode() + ", LOW); \n";
      else if (pinControl.equals("CCW") == true)
        ret = "\tdigitalWrite(" + pinBlock0.toCode() + ", LOW); \n\tdigitalWrite(" + pinBlock1.toCode() + ", HIGH); \n";
      else if (pinControl.equals("IStop") == true)
        ret = "\tdigitalWrite(" + pinBlock0.toCode() + ", HIGH); \n\tdigitalWrite(" + pinBlock1.toCode() + ", HIGH); \n";
      else
        ret = "\tdigitalWrite(" + pinBlock0.toCode() + ", LOW); \n\tdigitalWrite(" + pinBlock1.toCode() + ", LOW); \n";
      return ret;
 The idea is to read in the clockwise, counter-clockwise, instant stop, or ramp stop parameter and set the pins accordingly. Each parameter corresponds to a unique combination of 2 pins being on or off (4 total combinations).
Output and what the block looks like:
void setup()
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
void loop()
  digitalWrite(1, HIGH);
  digitalWrite(2, LOW);
