Kernel Module Port is Complete
A project log for Open Source Smart Display
Open Source, Open Hardware 17.3" touch screen smart display, based on the 96boards Dragonboard 410c
john-basistaJohn Basista 06/27/2019 at 19:200 Comments
Finally got the kernel module ported over for the SN65DSI86. Added the Innolux N173HCE-E31 panel added to the kernel as well and updated the device tree files to enable the bridge kernel driver. Need to create the pwm controller code for the bridge driver. Will probably work on the mechanical model a bit more before doing any other software stuff at this point.
