Weather vs Radiation readings
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 08/04/2015 at 11:300 Comments
The correlation between weather factors and background radiation levels have been investigated in an experiment that took place in Australia.
David put together one uRADMonitor unit and a weather station, and aligned the output data using a python script.
wind
As David explains:
"I’ve been running uRAD unit #12000003 here in Australia for around 12 months now and the only time I’ve really seen a solid increase in readings is during heavy rain which got me thinking, what other weather conditions affect radiation levels?"
weather
See the tools he used and more details on Weather vs Radiation readings
