Tips on installing a unit
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 07/01/2014 at 20:340 Comments
uRADMonitor should be mounted outside, but not directly exposed to rain or sun. A covered spot with some shadow in the free air is ideal (under the balcony, on a wall with protection from the Sun, etc). If the unit should be placed in a location where rain is likely to reach, consider protecting the uRADMonitor device with a plastic case. Should water get inside the unit, the device would be compromised. See the pictures below:
mounting_uradmonitor_rain_protection
Using a simple plastic bag (or several for multi-layer), we can protect the unit by mounting it inside the bag with the wires exiting on the bottom. The complete guide, can be found here.
