New unit in Prague
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 07/10/2014 at 08:150 Comments
The uRadMonitor network is constantly expanding for better Global coverage and a new unit has just become operational in Prague, Czech Republic. Feel free to support this project and join the network!
You can see the new unit's readings on the Global Radiation Map, and a comparison between its current values and the initial tests performed in Romania, here.
