Here are the initial measurements, performed in Timisoara, Romania, before sending the unit:
And here is the same unit 12000004, running at its destination in Netherlands:
Real time data can be accessed here.
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
