uRADMonitor A2 with Barometric sensor
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 08/05/2014 at 19:030 Comments
Here is a revision of the current Model A uRADMonitor detector. Codenamed the A2, it replaces the internal DS18B20 temperature sensor with the more versatile BMP180. The BMP180 is a low power, high resolution temperature and barometric pressure sensor, manufactured by Bosch. It comes with pre-calibration parameters that are used for accurate measurements.
uradmonitor_A2_barometric_2-text
The aluminium case has an extra hole that exposes the sensor directly to atmospheric conditions, unlike the model A that has the temperature sensor inside. This is a limited series of devices that will probably be distributed to locations where the pressure factor is essential for understanding the changes in background radiation levels. It is possible to also estimate the altitude based on the temperature and pressure readings.
uradmonitor_A2_barometric_3
These units are enclosed in the rugged aluminium enclosure as previous Model A units. When mounted outdoors, the connectors and the BMP180 sensor opening should be facing down, to avoid rain getting inside and damaging the sensitive electronics.
uradmonitor_A2_barometric_8
There are only a few A2 units available. To get one, click here. More pictures available on the uRADMonitor Facebook page. Share, like, spread the word, to help the network expand!
