Changed Booze Casing and added Oled display
A project log for Booze
Booze is a tiny beacon similar to tile in concept but the firmware is customizable and has a rechargeable lipo battery(60mAH).
boozebooze 06/29/2019 at 00:360 Comments
I have changed the casing to 43mm x 20mm x 10mm from the previous 40mm x 17mm x 10mm to give way for the 0.5" Oled display which has a board dimension of 17.8mm x 15.2mm x 3 mm. All materials to used are perfect fit for the new casing to use.
