So i got my parts in a couple weeks back. assembled them and needed something to hold them together. So i put a plate together and mounted them up. So far so good. A couple holes were slightly off. ill just oversize the plate holes and it should be fine. but here it is assembled. Need to get the motor controller mounted somewhere and start playing with the drive system. Make sure nothing binds up and it can turn smoothly etc...
