ALU Implemented
A project log for Computer build from first principals
Complete computer build from the logic to the compiler and operating system.
Michael WalkerMichael Walker 06/26/2019 at 06:100 Comments
 * The ALU (Arithmetic Logic Unit).
 * Computes one of the following functions:
 * x+y, x-y, y-x, 0, 1, -1, x, y, -x, -y, !x, !y,
 * x+1, y+1, x-1, y-1, x&y, x|y on two 16-bit inputs,
 * according to 6 input bits denoted zx,nx,zy,ny,f,no.
 * In addition, the ALU computes two 1-bit outputs:
 * if the ALU output == 0, zr is set to 1; otherwise zr is set to 0;
 * if the ALU output < 0, ng is set to 1; otherwise ng is set to 0.
// Implementation: the ALU logic manipulates the x and y inputs
// and operates on the resulting values, as follows:
// if (zx == 1) set x = 0        // 16-bit constant
// if (nx == 1) set x = !x       // bitwise not
// if (zy == 1) set y = 0        // 16-bit constant
// if (ny == 1) set y = !y       // bitwise not
// if (f == 1)  set out = x + y  // integer 2's complement addition
// if (f == 0)  set out = x & y  // bitwise and
// if (no == 1) set out = !out   // bitwise not
// if (out == 0) set zr = 1
// if (out < 0) set ng = 1
CHIP ALU {
    IN
        x[16], y[16],  // 16-bit inputs
        zx, // zero the x input?
        nx, // negate the x input?
        zy, // zero the y input?
        ny, // negate the y input?
        f,  // compute out = x + y (if 1) or x & y (if 0)
        no; // negate the out output?
    OUT
        out[16], // 16-bit output
        zr, // 1 if (out == 0), 0 otherwise
        ng; // 1 if (out < 0),  0 otherwise
    PARTS:
    // zx
    And16(a=x, b=false, out=zxTrue);
    Mux16(a=x, b=zxTrue, sel=zx, out=zerox);
    // nx
    Not16(in=zerox, out=notx);
    Mux16(a=zerox, b=notx, sel=nx, out=negx);
    // zy
    And16(a=y, b=false, out=zyTrue);
    Mux16(a=y, b=zyTrue, sel=zy, out=zeroy);
    // ny
    Not16(in=zeroy, out=noty);
    Mux16(a=zeroy, b=noty, sel=ny, out=negy);
    // f
    And16(a=negx, b=negy, out=andfxy);
    Add16(a=negx, b=negy, out=addfxy);
    Mux16(a=andfxy, b=addfxy, sel=f, out=fxy);
    // no
    Not16(in=fxy, out=notfxy);
    Mux16(a=fxy, b=notfxy, sel=no, out=out);
