Stable Power Module for Raspberry Pi on Drone
Professionally designed with power IC 5V-5A to provide stable power for Rasp Pi and built-in Serial port for connecting Rasp Pi to Pixhawk
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Stable Power Module is professionally designed with power IC 5V-5A to provide stable power for Companion computer as well as peripheral devices. It also has a built-in Serial port for connecting Companion computer and flight control. All connector in Stable Power Module is dronecode standard (JST GH and Molex CLIK-Mate).Technical detail:&#x1F396; Dimension: 60 x 35 x 15 mm&#x1F396; Weight: 21gram&#x1F396; Power Input: 7 to 36V power input (CLIK-Mate 2.00mm)&#x1F396; Power Output: 5V/5A&#x1F396; Features:+ Serial port (JST-GH)+ Reverse voltage protection+ Resist fluctuated, noise of electric power+ Green Led Indicator Power &#x1F396; Compatible: Compatible with all companion computer which have Rasp Pi pinout (2x20 2.54mm)+ All Raspberry Pi models (Rasp Pi Zero W, Rasp Pi 3B/B+, &#x2026;)+ ODROID-C2More detail: <a target="_blank" rel="noopener noreferrer" href="https://store.xbstation.com">https://store.xbstation.com</a><br>
