TTGO T-Watch Programmable And Networked Open Source Smart Watch That Interacts With The Environment As A Wearable Device
VIDEO:
Product Features
99
Hardware Specifications
Chipset ESP32, dual-core MCU, PMU power management
FLASH QSPI flash 16MB / PSRAM  8MB
SRAM  520 kB SRAM
Button power key , IO36
Extended function
USB to TTL CP2104
Modular interface UARTSPISDIOI2CLED PWM , PWMI2SIRGPIOcapacitor touch sensorADCDACLNA
On-board clock 40MHz crystal oscillator
Working voltage 2.7V-3.6V
Working current about 70mA
Sleep current about 3mA
Working temperature range -40 ~ +85
Size&Weight 46.47*43*20.4mm 43.19g
Display:  1.54 inch LCD capacitive touch screen
Sensor: BMA423 three-axis accelerometer, built-in step counting algorithm, activity recognition / tracking, advanced gesture recognition.
RTC clock :  PCF8563
Power Supply Specifications
Power Supply USB 5V/1A
Charging current 500mA
Battery 3.7V lithium battery
Wi-Fi
Standard FCC/CE-RED/IC/TELEC/KCC/SRRC/NCC
Protocol 802.11 b/g/n(802.11nspeed up to150Mbps)A-MPDU and A-MSDU polymerizationsupport 0.4μS Protection interval
Frequency range 2.4GHz~2.5GHz(2400M~2483.5M)
Transmit Power 22dBm
Communication distance 300m
Bluetooth
Protocol meet bluetooth v4.2BR/EDR and BLE standard
Radio frequency with -97dBm sensitivity NZIF receiver Class-1,Class-2&Class-3 emitter AFH
Audio frequency CVSD&SBC audio frequency
Software specification
Wi-Fi Mode Station/SoftAP/SoftAP+Station/P2P
Security mechanism WPA/WPA2/WPA2-Enterprise/WPS
Encryption Type  AES/RSA/ECC/SHA
Firmware upgrade UART download/OTA>span class="font5">)
Software Development Support cloud server development /SDK for user firmware development
Networking protocol IPv4IPv6SSLTCP/UDP/HTTP/FTP/MQTT
User Configuration AT + Instruction set, cloud server, android/iOSapp
OS FreeRTOS
Appearance Specifications
T-Watch onboard:
1.54 inch LCD capacitive touch screen: ST7789V
Touch screen chip: FT5206
Three-axis accelerometer: BMA423
PMU power management: AXP202
RTC clock module: PCF8563
Expand the interface:
Support microphone: MSM261S4030H0
Support SPI TF memory card
2 digital I/Os: GPIO25, GPIO26 (supports ADC, DAC)
Support I2C, UART, SPI communication protocol
说明书-(2)_04
T-Watch onboard:
model1
Component Layout
model2model3Product Pins
model4
More Information:https://github.com/Xinyuan-LilyGO/TTGO-T-Watch
                                https://t-watch-document-en.readthedocs.io/en/latest/index.html
Product Details
Accelerometer
• Chip: BMA423
• Latest generation triaxial, low-g acceleration sensor from Bosch
• ultra-small
• digital interfaces
• 2 bit digital resolution and embedded intelligence,
• allows low-noise measurement of accelerations in 3 perpendicular and thus senses wrist
tilt, tab/double tab and enables plug ’n’ play step counting especially in wearable devices.
Recommended for
- Step-counting in wearable devices
- Wake up display on wrist tilt
- Low power user interaction by tab/double tab
- Advanced gesture recognition
- Activity recognition/tracking
- Advanced power management for mobile devices
- Tilt compensation for electronic compass
t-watch-04
Product Composition
1 x T-Watch
1 x Female Pin extension board
1 x Black strap(25.5CM)
1 x Charging cable
1 x Data cable
1 x Small screwdriver
4 x Small screw
1 x Blue small rag
1 x Manual
1 x Exclusive box
QQ图片20190612114348Email :  lily@lilygo.cc
Twitter :  lilygo@lilygo9
Facebook : lily@lilygo.cc
Skype :  seatechnolgy@outlook.com
WhatsApp :  +8613928411439
Phone Number : +86 13928411439
