this helmet now has a bluetooth headset system
09/09/2019 at 20:35 • 0 commentsalong with the indicators i now added a bluetooth headset system into the helmet.
i used this bluetooth receiver(used for cars).
you can see a little extension of the bluetooth board coming out near the front glass. that is for turning the bluetooth on and off and volume up and down contolls.
Then covering the whole wiring with the inbuilt foam cover in helmet.
Drilled a small hole at lower right portion of the helmet just below the ear from where i can push the button of voltage regulator to turn on/off the entire electronics.
TADDAA!! and thats one more feature now :)
