Lora ESP32 business card
The ESP32 Lora Business Card is a fully operational lora communicator in a thin small card.
The ESP32 lora business card isba very thin & small lora txt communicator with a high resolution display in color, 4 touch capacitive buttons, and ESP32 MC, a PCB 868/915 mhz tunable antenna and a RFM95 SPI transceiver (lora/lorawan). Can be used as a geek business card with media content which can be updated thru wifi when your resume is updated or when you have a new project to promote. Can also be used to offer as a game bank (esp32 emulators). Can be used as an emergency lora transmitter or a lorawan node...
Lora tests
JPEG Image - 3.37 MB - 07/07/2019 at 16:29
Preview
Download
Firsts tests
JPEG Image - 5.24 MB - 07/07/2019 at 16:26
Preview
Download
First PCB arrived
JPEG Image - 197.73 kB - 07/03/2019 at 12:35
Preview
Download
jousis wrote 07/03/2019 at 10:09 point
Think about using an epaper display. Could show contact info or your logo when powered down.
pcadic wrote 07/03/2019 at 23:44 point
good idea. Tryong to find a cheat epaper
de∫hipu wrote 07/03/2019 at 07:45 point
That looks nice, how are you going to power it?
pcadic wrote 07/03/2019 at 23:43 point
just thru a single usb plug. Adding a battery would  mane it too thick
nbc12 wrote 07/04/2019 at 00:38 point
You might want to look into lithium ceramic batteries depending on how much power you need. They look like they can be extremely thin.
pcadic wrote 07/06/2019 at 10:37 point
yes could be cool. My idea was to generate curiosity, forcing people to plug it into a USB slot on a computer.  I'm on  the correction of version 1.2 this week end. I'll add 2 pads to solder a battery and possibly a chaging area if I have room
