Compared to the original #192:LED design. Nearly everything did change
- smaller: 15.8mm x 14.6mm
- No complicated Multiplexing anymore! LEDs are WS2812 style ones in a metric 1515 package
- smarter: MCU is a SAMD21
- USB: quite more convienat and easier to connect
- Bootloader is same as on Adafruit's Trinket M0
- Easy Arduino IDE support
- Easy Circuit Phython support
- Using of Adafruits's Neopixel Library
- Programming and Powering via USB
Alex
Ethan Durrant
Wim Van Gool
This is the coolest thing.
