Lumps - Spotlight Drone
A GPS controlled Spotlight Drone
Once deployed, Lumos will hover above the designated area until its battery reserves are depleted at which point it will return to the base location and where it will be collected and recharged. The process will repeat until the units are no longer needed. To reduce interference with rescue operations it will fly at a distance of 200 to 300 feet above the area as to be out of audible hearing range and most physical obstacles.
Adobe Portable Document Format - 3.33 MB - 07/06/2019 at 21:24
Preview
Download
