20190707_190412.jpgspool brace with skateboard bearingimage/jpeg - 268.35 kB - 07/07/2019 at 18:00 |
20190707_190240.jpg5cm feet to elevate the printer, to make room for cooling tunnel for mainboard and to move the mainboard away from the heated bedimage/jpeg - 211.73 kB - 07/07/2019 at 18:00 |
20190707_190154.jpgpreliminary fan funnel until the mainboard is moved to base plate and a dedicated mainboard fan tunnel is designed and installedimage/jpeg - 176.94 kB - 07/07/2019 at 18:00 |
20190707_190323.jpgspacer to keep the bowden tube from moving backwards while the extruder retractsimage/jpeg - 132.79 kB - 07/07/2019 at 18:00 |
