Features:
- PCB sizes: 17mm/0.67" Width ~ 16mm/0.63" Height
- PCB Thickness: 1.6mm
- Surface Finish: LeadFree HASL-RoHS
- Each PCB has tow sets of four holes to soldering wires/headers compatible with breadboards
- Power supplay: 3-5V DC
- Intelligent reverse connect protection
- The control circuit and the LED share the only power source
- Contains a constant-current driver cooked right into the LED package
- The control circuit and RGB chip are integrated in a package of 5050 components, for a complete control of pixel point
- Each pixel of the three primary color can achieve 256 brightness display, completed 16777216 color full color display, and scan frequency not less than 400Hz/s
- Send data at speeds of 800Kbps
- Only need 1 pin/wire to control them. Cascading port transmission signal by single line
- The color of the light were highly consistent, cost-effective
Typical Connection
As much as VDD and GND both are common.
Hugo
