Prototype #2 almost finished
A project log for KELPIE: Subtractive Synth for Keyboard Controllers
A portable, cheap, and easy to use, monophonic + polyphonic digital synthesizer for use with a MIDI controller
kenneth-marutKenneth Marut 09/12/2019 at 18:340 Comments
Finished assembling all electronics and the enclosure (except for knobs). So far everything's working as expected! I'm working on making another prototype which I should hopefully be able to knock out in the next week and then I'll likely go back to the firmware as there are a good amount of bugs that need to be sorted out. Anyway, here are some photos of the build. I'm really happy with the new 30 pin flex connector.
