3Dprinter firmware run on raspberryPi
PandaPi is a 3D printer firmware based on Marlin,but runs on raspberry Pi. Hope this PandPi can do more possibilities in the FDM 3D printer
PandaPi is a 3D printer firmware based on Marlin,but runs on raspberry Pi.and have a RAMPS equivalent board that mounts on the raspberry Pi.
PandaPi: uses a Raspberry Pi to control 3D printer directly,except the temperature control which is just to maintain the temperature.
Klipper: uses a Raspberry Pi to parse G-code,map out curves,set accelerations,improving the speed of FDM 3D printing.
it is more faster than Klipper.
1) control the 3D printer directly and Klipper need send the command to printer board's MCU.
2) the GPIO being able to signal at 10+ Mhz for the 2B+ as compared to 8/32bit MCU limit of about 10Khz/200khz for steps.
after the firt stable version is released,I will opensource it.
how do this assure the real time control?
We don't guarantee real-time control, we guarantee motor coordination. and the Pi is more
than fast enough that it is not a problem.
View all 4 project logs
