64-bit 3D printer,Run marlin on RaspberryPi
Run Marlin & Octoprint on Raspberry Pi directly
www.pandapi3d.com Software 1.better prints at faster speedsIf you want to do more higher speed or print some short line or corner the higher process speed is very important,otherwise there will be some slight on the surface. so 32 bit MCU is better,but if you want add more function like web camera,HDMI LCD... little space,for friendly easy to use this PandaPi runs on the powerful Raspberry Pi is the best. 2.Octoprint + marlin.the marlin code is very stable and are familiar with us, if we have a good idea or control algorithm, we can change it easily. 3.No arduino, no platformIO.online compile. Hardware 1.Support mixed use of 3V-24V fans 2.optocoupler for bed proximity sensor 3.Low temperature mosfet at high curre
FAQ:
  1. what's the difference from Klipper
    PandaPi: use RPi to control 3D printer directly,except the temperature control which is just to maintain the temperature.
    Klipper: uses a RPi to parse G-code,map out curves,set accelerations,and then send the motor command to the MCU via uart.
  2. Why is there a mcu?
    RPi has not enough GPIO pin for handle all the motors,hotend,bed,endstop,LCD,auto bed level,run out sensor.
  3. how do this assure the real time control?
    about the real-time, I did a test . it is not real time actually,but we guarantee motor coordination. and the RPi is more than fast enough that it is not a problem.and I test it with pi4 the cpu speed is quickly than pi3! BTW I test it with all the function like camera octoprint,they are used a lot of RAM but little CPU.
  4. there is a great improve to the pandapi software for high speed printing with high pressure cpu loaded. here is the a test.this is the output signal of the one raspberryPI'GPIO,and displayed by the oscilloscope.
pandaPI_sch.pdf
Panda Pi sheild circuit schematic
Adobe Portable Document Format - 100.91 kB - 08/26/2019 at 02:20
Preview
View all 40 project logs
Films4You wrote 12/23/2020 at 23:58 point
No servo ports??
mark wrote 12/24/2020 at 00:42 point
there is one servo port for BLtouch.
metalbug wrote 04/24/2020 at 02:34 point
请把STM32去掉,用pI做输入输出,集成TMC2009,你还是有的赚
mark wrote 04/24/2020 at 03:33 point
可是pi没有那么多gpio给风扇和挤出头,所以才外加stm32
jedisintraining3 wrote 04/15/2020 at 04:30 point
One of the truly most amazing projects I have seen so far! Keep it up, I hope to be buying soon.
mark wrote 04/24/2020 at 03:32 point
thank you so much!
TheMinerHD wrote 04/03/2020 at 00:49 point
You're listing a rpi3b/+ as well as an rpi4b. Wich one would you recommend using/ is there a real difference between those two? I have an rpi3b+ which i would use if its working fine in this configuration/ there istnt a big difference. If there is a decently noticable difference i would buy a rpi4b and use the rpi3b+ for octoprint only.
Thank you for providing such a nice product. :)
mark wrote 04/14/2020 at 01:29 point
Thanks for your support, if we want to run more software on pi, the cpu of pi4 is  faster and better.
furkanbr wrote 12/09/2019 at 01:13 point
that looks awesome! how did you run marlin firmware on linux is that possible !
mark wrote 12/28/2019 at 11:48 point
thanks!If you know how the marlin and the Linux works,and some porting experience, that's not difficult.
furkanbr wrote 01/09/2020 at 01:17 point
how can i learn this porting work my friend , what is the name of this work ? i think this is so cool i would love to know that
Eirik wrote 11/27/2019 at 14:11 point
Going to ordner one for christmas as a gift from the kids ;) Just curious if its possible to use an Orion precision piezo kit with this controller, the voltage is ok, but wondering how to wire it as the Orion kit only uses signal, ground and power, versus the bltouch that has 5 wires in total.
Best of regards
Eirik
mark wrote 12/03/2019 at 12:55 point
Hi Eirik,   Thank you very much!  here you can find how to wiring https://github.com/markniu/PandaPi/wiki.  hope you can have fun with it!
nife87 wrote 11/01/2019 at 04:39 point
Just a quick remark: The X gantry on the CE3 in the video looks severly inclined, especially noticeable when ABL is performed.
mark wrote 11/01/2019 at 09:34 point
that's why we use the ABL that can calibration it
Daimein2007 wrote 10/12/2019 at 01:18 point
Just received a project board and will be doing some testing and posting some results with video. Very excited to see what this little jewel can do.
mark wrote 10/12/2019 at 03:22 point
