An enclosure for the charger and 500mAh LiPo
A project log for Ant USB-C LiPo Charger
The smallest USB-C LiPo charger
beast-devicesBeast Devices 07/31/2019 at 20:230 Comments
I have used Fusion 360 to make a quick enclosure for the charger and a 500mAh LiPo battery. Have made some renderings to show the progress. The outside dimensions of the enclosure are 55 x 35 x 10 mm. The design is prepared for a cover on the top, which will be held by two latches and two M3 screws, screwed directly in the plastic.
Going to it print on my Ultimaker 3 soon.
