Asper : an open-source social robot
Asper is a raspberry pi based social robotics platform with interactive design, easy integration and dozens of pre-programmed animations.
Just like most of us, I would love to have a personal robot companion with me, but the problem is there is no such thing available in the market right now. All the personal assistants and smart-speakers lack user-experience, and most of the robots are expensive, lack intelligence and are mostly useless. I strongly believe that the open-source community can make affordable personal robots a reality!
Asper is an easy to use social robotics platform based on raspberry pi.
It comes with dozens of pre-programmed face and body animations and you can even build your own animations and integrate them with your projects.
With it’s easy to use library, easily integrate Alexa or google home with Asper and give these Ai some personality.
Even better, Build your own personal assistant or give a fun personality to your raspberry pi projects!
Opportunities are endless!
  • 1 × Raspberry pi 3 Model A+
  • 1 × Asper's PCBs There are 3 PCB and 2 adapter boards + 2 ribbon cables
  • 2 × 5000 mah battery Batteries are connected in parallel so your can even use single battery as well
  • 1 × 2 Servos If your buy Asper from my website, you will get Asper with slightly quitter servos in the head because of the custom grease treatment.
  • 1 × 1 stepper motor
View all 7 components
