Plugin For Importing Audio from DAW
A project log for Binaural Audio Editor
This is an audio application that produces 3D binaural audio from 2D mono audio samples and positional information given by GUI.
pablo-antonio-camacho-jrPablo Antonio Camacho Jr. 12/16/2019 at 18:590 Comments
I made a plugin to export audio from a DAW(Digital Audio Workstation) to Binaural Audio Editor sound track.
This plugin allows one to do advanced editing on audio in a preferred DAW and then export the audio to Binaural Audio Editor to have it spatialized in 3D.
The plugin needs to be compiled and installed into a directory where DAW looks for LV2 plugins. The absolute path to resources folder of binaural audio editor must be specified which should look something like this your-folder/binaural-audio-editor/src/timeline-track-editor/resources/ .
https://github.com/adct-the-experimenter/import-audio-DAW-BAE
If using the plugin, please make sure that the format of audio is 16-bit PCM in Audacity
The current release build v1.2 does not have this capability yet.
Although with the release build, the audio can be loaded by opening the file binaural-audio-editor/src/timeline-track-editor/resources/imported_audio_DAW.wav .
