Specifications
Signal Outputs
   Analog Outputs
Number of Channels :     3
Full Scale Range :         0 to VREF
Resolutions :            Depended on the PWM resolutions
Supply Voltage:          3 to 5.5V
VREF Voltage:            3 to 5.5V (Do not higher than VCC)
Support PWM Frequency:  100Hz to 10KHz
Output Minimum Voltage:  6mV
Output Max Voltage:      VCC – 100mV
Output Current:          30mA
Recommend link:http://www.inhaos.com/search.php?keywords=DAC-3000&x=0&y=0
