Loko-Offline GPS tracker with 270 days battery
Loko is the 12 gram GPS tracker with extreme battery life.
Starting from
has orders / reviews
Ships from
Loko is an open source, battery operated radio-based GPS tracker. It’s a tiny, simple, useful device that sends navigation data to its receiver via peer-to-peer LoRa radio. Unlike other similar technologies, there is no ongoing subscription cost. Loko is radio communication based and doesn’t require a sim-card or monthly fee. It also works anywhere, even if there is no 2G/3G/LTE coverage. Loko is being configured to transmit navigation data to existing LoRaWAN® networks. Loko is designed with Ultra Low Power consumption in mind which can work 30+ days on a single charge with the tiny, built-in coin cell battery. The transmitter is only 12 grams (0.42 oz) and is slightly bigger than the tip of a finger (30 mm x 23 mm). for more information visit : https://www.nolilab.com/
Loko operates with 2 units: The Ground unit (receiver), and the Air unit (transmitter). The Air unit transmits navigation data to the Ground unit at a pre-configured time interval, and the Ground unit transmits the received data to a smartphone app via Bluetooth (iPhone only with this version). ?is an android version being developed, and if so, will an android version be available by the time the campaign ships? The app automatically shows the location of any Loko Air modules on a 2D map.
Example use-case for finding a lost drone
  • Attach the Loko Air module to your drone and operate as you normally would.
  • If your drone goes missing, turn on the Loko Ground Unit to search.
  • Once the Ground unit receives signal from the Air unit, the location of the Air unit will appear on the Loko smartphone app.
  • Follow the directions on the Loko app to recover your drone.
Features & Specifications
  • Works anywhere you go
  • No cellular signal or internet required
  • No monthly fees
  • Range +20km
  • Locate lost objects with pinpoint accuracy.
  • Up to 270 days battery life per charge for Air unit (battery life depends on how often the Air unit is set to transmit its location)
  • Expandable up to 30 Air units per Ground unit
visit nolilab
  • 1 × Seeed LoRa-E5 Module Lora radio module , https://www.seeedstudio.com/LoRa-E5-Wireless-Module-p-4745.html
  • 1 × Stm32L072 Manin microcontroller ,, QNF case
  • 1 × GPS PA1010D tiny gps module
View all 17 project logs
Akio Sato wrote 06/21/2026 at 09:24 point
After a long time, I've added many new features and also shared the source code on GitHub.
What's new:
GPS Logger Mode
1. Loko can now operate purely as a GPS logger. Users can disable radio transmission entirely and use the device only for GPS data logging.
Browser-Based Log Visualizer
2. I created a web-based log visualization tool that allows users to view and analyze recorded tracking data directly in their browser:
https://www.nolilab.com/loko-config-tool/
3. One-Click Firmware Updater
Firmware updates are now much easier with a new one-click update tool.
4. Improved Mapping Support
The Loko App no longer relies on Google Maps. It now supports Esri Maps and OpenStreetMap, and users can download map data for offline use.
5. Custom Map Support
The Loko App now supports custom maps, including KMZ and GeoTIFF formats.
6. User Interface Improvements
Many UI enhancements have been added, including the ability to:
7. Assign custom names to trackers
8. Change tracker colors
9. Adjust tracker icon sizes
10. Customize the map display experience
And much more
and all software and hardware completely open source.
https://www.nolilab.com/software/
teraz wrote 03/29/2022 at 14:59 point
is possible using this in mesh lora network in ukraine?
Akio Sato wrote 04/03/2022 at 07:29 point
yes
Nazwa wrote 04/03/2022 at 16:21 point
In my opinion in ukraine device without screen, keys is not usefull.
how long this device work (week, month?) and what distance I can send message? (10-100km)
Dave Ann Buster wrote 03/25/2022 at 23:53 point
Please do be safe. That said is this crowd sourced yet? Would love to support this. Great work!
gigillo73 wrote 03/11/2022 at 18:52 point
Hi. I'm interested to track the GPS position of a person with Alzheimer disease. According to your experience , is it a thing that can work on the TTN? How long lives the battery inside? Thanks.
Akio Sato wrote 04/03/2022 at 07:30 point
it can connect to TTN, I will add this to software configuration tool as well
gigillo73 wrote 04/03/2022 at 08:06 point
Super! When could be available this product? Briefly I have to buy this for the person with Alzheimer...I can't wait too time. Best regards
Akio Sato wrote 04/03/2022 at 09:25 point
The unexpected war in Ukraine added delay on development, but now first stage of development finished, soon  crowdfunding campaign will be live
Akio Sato wrote 03/08/2022 at 08:15 point
Because of war in Ukraine , I will have small delay in these days . it is getting hard to work for me
morgan wrote 03/09/2022 at 01:22 point
Sorry to hear this. Stay safe.
ravindumadushan395 wrote 02/16/2022 at 17:04 point
hiii where can i find the project files?
this project is greate
Akio Sato wrote 04/03/2022 at 07:31 point
https://github.com/tomipiriyev/Loko
G wrote 02/13/2022 at 21:07 point
Looks cool! Where are the files?
Akio Sato wrote 02/13/2022 at 22:00 point
https://www.crowdsupply.com/dronee/loko.   scroll down there I GitHub link
G wrote 02/14/2022 at 05:16 point
Thanks!
G wrote 03/12/2022 at 05:50 point
Thanks, but under the software directory there's nothing but a few empty readme files.
CzarofAK wrote 01/19/2022 at 08:39 point
any chance, that we can try out this super little tracker soon?
What are your intentions? Crowdfound, open source or else?
Would love to buy/produce at least 5 trackers
Samuk wrote 11/06/2021 at 22:56 point
what's the chip? Any chance of getting meshtastic.org running on it?
Akio Sato wrote 11/08/2021 at 12:53 point
I am not sure what it is ,  the chip is STM32L072
Samuk wrote 11/08/2021 at 13:32 point
It's a p2p LoRa mesh network, running on ESP32/ NRF52 dev boards. It has  Android/iOS apps for mapping: https://meshtastic.org/
Akio Sato wrote 11/08/2021 at 13:38 point
I see, I use Stm32L072 as MCU and LoRa-E5 (STM32WLE5JC) Module as Lora module.  MCU and Lora-E5 communicates via UART
Samuk wrote 11/11/2021 at 13:48 point
Ah I think that's too slow for Meshtastic :( If you did an NRF52 version that would work.
Akio Sato wrote 11/11/2021 at 14:46 point
NRF52 is too expensive and effected by silicon shortage, and a little bit big , not suitable for Loko
Akio Sato wrote 11/06/2021 at 17:12 point
Planning to make Crowdsupply campaign, what is your thoughts?
morgan wrote 11/06/2021 at 17:29 point
would support
Akio Sato wrote 11/06/2021 at 18:14 point
much appreciated
