Loko Farm Managment System
10/01/2025 at 15:52 • 0 commentsI’ve started developing a web-based farm management platform that allows farmers to monitor all their sensors and trackers in one place.
To make this possible, I built a receiver station with LTE connectivity. The receiver collects data from farm sensors via LoRa and then transmits it to the server using the 4G/LTE network.
I’ll be sharing more pictures and details about the receiver stations soon. I’d love to hear your thoughts and feedback.
Loko available now from SeeedStudio
12/30/2024 at 09:40 • 0 comments -
Customising Loko firmware
12/06/2022 at 04:22 • 0 commentsIn order to customize or develop firmware for Loko air units, you’ll need to connect an ST-link debugger to the unit. To make this easier, I equipped Loko Air units with a USB-C connector and hardware debug pins on a small USB-C extension board. This lets you use jumper cables to easily connect the debugger to Loko and start coding. CubeIDE is the preferred method to write code to Loko Air unit. All the firmware code is available in the project’s GitHub repo.
The Loko Ground unit firmware is written in on MicroPython, which makes coding much faster and more accessible. For this task, you’ll need to install the ThonnyIDE on your PC and connect it to the Loko Ground unit via USB. No additional hardware is required.
Loko Multi Connection
11/30/2022 at 05:58 • 0 commentsConnecting multiple Loko Air units ( GPS transmitters) to a single Ground unit ( receiver )
for ordering Loko : https://www.crowdsupply.com/nolilab/loko
Loko Teardown - lets see what is inside the loko
11/23/2022 at 04:35 • 0 comments -
Loko short demonstration
11/18/2022 at 05:42 • 0 comments -
Hurray!). Loko is open for pre-orders on crowd supply
11/07/2022 at 19:58 • 0 comments -
power consumption with new microcontroller.
09/09/2022 at 13:53 • 0 commentsafter stm32L072 went to silicon shortage , I changed the pcb design, now used only E5 module as main MCU and Radio module . For this I developed native firmware for stm32WL chip .
so far I achieved sleeping current consumption 18uA, working current consumption 36mA.
I used nordic power profile kit 2 to measure the consumption precisely.
finishing the hardware and software tests, moving to field tests. Loko coming very soon.
Moving to native firmware on LoRa E5 ( stm32WL)
05/20/2022 at 12:34 • 0 commentsBecause of silicon shortage I cannot find STM32L072 chip that I used on last prototype, I decided to remove the secondary MCU and develop native firmware on stm32WL chip ( Lora-E5)
Firmware released on GitHub
04/03/2022 at 07:33 • 0 commentsstable version of firmware added on GitHub .
Akio Sato
