URU Key - final hardware design
A project log for URU Key
URU Key - a biometric FIDO2 Authenticator built with ESP32 / ATECC508A / FPC1020
Andrey OvcharovAndrey Ovcharov 04/06/2020 at 07:460 Comments
I am happy to say that I’m finally done with the hardware design of the URU Key device.
It took a few months and number of iterations to complete it but now I have the device I wanted to have.
The size of the PCB is only 40x15mm, it’s comparable to a regular fitness tracker.
Main features are:
I understand that I’m not a hardware engineer and the design, probably, has a lot of mistakes. But for hobbyist, it is definitely good. It definitely solves the problem I wanted to solve - to create small wearable authenticator device with the biometric scanner and wireless connection.
The remaining challenges have to be solved on the software side where I am a bit more experienced than in hardware. That means it will be more of a just work than research and I can say I am very optimistic about the result of the project now.
Oh, and case. The device needs case.
