First Steps
A project log for My Auto-Router
I am not that impressed with auto-routers. Why are they so bad?
agpcooperagp.cooper 07/20/2019 at 02:230 Comments
First Steps
There is a lot of work setting up the interface between the schematic capture and PCB layout applications and the auto-routing applications. So I will just read in a simple text files to begin.
The Schematic
One of my first PCB schematics was a DTL (Diode Transistor Logic) three input NAND gate. Here is a KiCAD version.
First the KiCAD schematic:
And the KiCAD PCB:
Now I have tried to get a single sided PCB version of this design (in Eagle and EasyEDA) but it is surprisingly difficult to do. KiCAD does not even offer the option. In the end I had to hand route a design (okay it has nine copies):
With a bit of imagination you should see the KiCAD PCB here (map.txt):
And the links list:
SRC DST
 1    7
 7    8
 2   13
13   22
 3    9
 4   10
 5   11
 6   24
24   25
12   14
14   19
14   15
15   16
16   21
17   18
18   23
18   20
26   27
After a Day of Coding
Here is a series of images as I debugged and got the penalty function working.
Well its just about getting something on screen to look at!
I want to penalise paths that get too close to the pins (thus the small red dots):
Note: The red tracks failed to find a legal path. A diagonal path between tracks was consider illegal.
Here is a working case:
Note: The links are exactly honoured and thus the ugly links.
Finally with a pseudo-Steiner Tree modification gives a pretty reasonable result:
So for a single side PCB I have a result that works (for the small example).
So how is that, all of the above in less than 600 lines of code!
A lot more to do, add multi-able layers and back-tracking when the algorithm fails.
Update
Added some code to randomly swap around the links to see if I can improve the result.
I gave the router 1 second, it looked as 2083 options and reduced the penalty from 682 to 582:
I have been looking at the passes that failed to determine if there is an easy heuristic I could apply. Even in the above image the I can see faults that could be fixed that would improve the success rate.
A couple of papers suggested:
Currently I completely randomise the links for a run and run a many as I can in one second.
Here is an example where I use the above approach (i.e. a single run) but include a congestion penalty:
You can see that the congestion penalty has moved the tracks away from the pins (and other tracks) leaving space for later tracks. This in my mind is a pretty good result (for a single run). Without the congestion penalty you get:
Code
I have posted the code for the above.
Paper by Eric Rosenberg on Iterative Routers
I found a paper by Eric Rosenberg that describes an iterative method for improving the router performance. Here is a simplified version of his algorithm:
It should be noted the algorithm can be unstable and much of Eric Rosenberg's paper is about approaches to resolve this issue.
AlanX
