Importing a KiCAD SPECCTRA File
A project log for My Auto-Router
I am not that impressed with auto-routers. Why are they so bad?
agpcooperagp.cooper 07/24/2019 at 10:250 Comments
The KiCAD SPECCTRA File
KiCAD can export PCBs as "dsn" or SPECCTRA files. These file are ASCII and use Symbolic Expression format (often called  S-Expr format).  The SPECCTA specification is quite complex but for this application I only need the Board Area and the Pin locations.
I have modified code by https://github.com/benthepoet/c-sexpr-parser to read "dsn" format and then write it out again. As the rewritten "dsn" file was readable I assume that the code is correct.
Here is the modified "sexpr.h" and "sexpr.c" files:And finally my code to read/write the "dsn" file:
enum SNodeType {
  LIST,
  STRING,
  SYMBOL,
  INTEGER,
  FLOAT
struct SNode {
  struct SNode *next;
  enum SNodeType type;
  union {
    struct SNode *list;
    char *value;
struct SNode *snode_parse(FILE *fp);
void snode_free(struct SNode *node);
#include <ctype.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "sexpr.h"
#define BUFFER_MAX 511
static char quoteChar='"';
int is_float(char *str) {
  char *ptr=NULL;
  strtod(str,&ptr);
  return !(*ptr);
int is_integer(char *str) {
  char *ptr=NULL;
  strtol(str,&ptr,10);
  return !(*ptr);
int is_lst_term(int c) {
  return ((c==EOF)||(isspace(c))||(c=='(')||(c ==')'));
int is_str_term(int c) {
  return ((c==EOF)||(c=='"'));
char *read_value(FILE *fp,int *c,int (*is_term)(int)) {
  int len=0;
  char buffer[BUFFER_MAX+1];
  while ((!is_term(*c=fgetc(fp)))&&(len<BUFFER_MAX)) {
    buffer[len]=(char)*c;
    len++;
  buffer[len]='\0';
  char *str=malloc((unsigned int)(len+1)*sizeof(char));
  return strcpy(str,buffer);
// Recursively parse an s-expression from a file stream
struct SNode *snode_parse(FILE *fp) {
  // Using a linked list, nodes are appended to the list tail until we
  // reach a list terminator at which point we return the list head.
  struct SNode *tail=NULL,*head=NULL;
  int c;
  char lastSymbol[BUFFER_MAX+1]="";
  while ((c=fgetc(fp))!=EOF) {
    struct SNode *node=NULL;
    if (c==')') {
      // Terminate list recursion
      break;
    } else if (c=='(') {
      // Begin list recursion
      node=malloc(sizeof(struct SNode));
      node->type=LIST;
      node->list=snode_parse(fp);
    } else if ((strcmp(lastSymbol,"string_quote")==0)&&(!isspace(c))) {
      // Read symbol
      ungetc(c,fp);
      node->value=read_value(fp,&c,&is_lst_term);
      // Put the terminator back
      ungetc(c,fp);
      node->type=SYMBOL;
      strcpy(lastSymbol,node->value);
      quoteChar=lastSymbol[0];
    } else if (c=='"') {
      node->type=STRING;
      node->value=read_value(fp,&c,&is_str_term);
    } else if (!isspace(c)) {
      // Read a float, integer, or symbol
      ungetc(c,fp);
      ungetc(c,fp);
      if (is_integer(node->value)) {
        node->type=INTEGER;
      } else if (is_float(node->value)) {
        node->type=FLOAT;
      } else {
        node->type=SYMBOL;
    if (node!=NULL) {
      // Terminate the node
      node->next=NULL;
      if (head==NULL) {
        // Initialize the list head
        head=tail=node;
      } else {
        // Append the node to the list tail
        tail=tail->next=node;
  return head;
// Recursively free memory allocated by a node
void snode_free(struct SNode *node) {
  while (node!=NULL) {
    struct SNode *tmp=node;
    if (node->type==LIST) {
      snode_free(node->list);
    } else {
      // Free current value
      free(node->value);
      node->value=NULL;
    node=node->next;
    // Free current node
    free(tmp);
    tmp=NULL;
And my code to read the "dsn" file and then rewrite (export) it:
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <string.h>
#include "sexpr.h"
void run_tests(struct SNode *node);
int main(int argc, char *argv[]) {
  // Unused parameters
  (void)argc;
  (void)argv;
  FILE *fp=fopen("DTL.dsn","r");
  struct SNode *node=snode_parse(fp);
  fclose(fp);
  run_tests(node);
  snode_free(node);
  return 0;
void run_tests(struct SNode *node) {
  int depth=1;
  int stackSize=1;
  struct SNode* current=NULL;
  struct SNode** stack=malloc((unsigned long)stackSize*sizeof(struct SNode));
  FILE *F1=fopen("test.dat","w");
  stack[0]=NULL;
  current=node->list;
  fprintf(F1,"( ");
  while (depth>0) {
    if (current==NULL) {
      depth--;
      fprintf(F1,") ");
      current=stack[depth];
    } else if (current->type==LIST) {
      stack[depth]=current->next;
      if (depth>=stackSize) {
        stackSize=depth+1;
        stack=(struct SNode**)realloc(stack,(unsigned int)stackSize*sizeof(struct SNode));
      fprintf(F1,"\n");
      for (int i=0;i<depth;i++) fprintf(F1,"  ");
      fprintf(F1,"( ");
      depth++;
      for (int i=0;i<depth;i++) printf("  ");
      current=current->list;
    } else if (current->type==SYMBOL) {
      fprintf(F1,"%s ",current->value);
      current=current->next;
    } else if (current->type==STRING) {
      fprintf(F1,"\"%s\" ",current->value);
    } else if (current->type==INTEGER) {
      fprintf(F1,"%d ",atoi(current->value));
    } else if (current->type==FLOAT) {
      fprintf(F1,"%f ",atof(current->value));
  fclose(F1);
Here is the first few lines of the exported "dsn" file:
( pcb /home/alanx/KiCAD/DTL/DTL.dsn
  ( parser
    ( string_quote " )
    ( space_in_quoted_tokens on )
    ( host_cad "KiCad's Pcbnew" )
    ( host_version "4.0.7-e2-6376~61~ubuntu18.04.1" ) )
  ( resolution um 10 )
  ( unit um )
  ( structure
    ( layer F.Cu
      ( type signal )
      ( property
        ( index 0 ) ) )
    ( layer B.Cu
      ( type signal )
      ( property
        ( index 1 ) ) )
    ( boundary
      ( path pcb 0 130810 -95250 130810 -120650 175260 -120650 175260 -95250 130810 -95250 130810 -95250 ) )
    ( plane Earth
      ( polygon F.Cu 0 129540 -93980 176530 -93980 176530 -121920 129540 -121920 ) )
    ( via "Via[0-1]_600:400_um" )
    ( rule
      ( width 250 )
      ( clearance 200.100000 )
        ( type default_smd ) )
      ( clearance 50
        ( type smd_smd ) ) ) )
Now all I have to do is to export what I need.
Here is the scan of the "dsn" file for what I need:
PCB DTL
component Capacitors_THT:C_Rect_L7.0mm_W2.0mm_P5.00mm
  place C1 154940 -105410 front 180
component Diodes_THT:D_DO-35_SOD27_P7.62mm_Horizontal
  place D1 165100 -110490 front 180
  place D2 157480 -107950 front 0
  place D3 139700 -107950 front 0
  place D4 139700 -110490 front 0
  place D5 139700 -113030 front 0
component Socket_Strips:Socket_Strip_Straight_1x06_Pitch2.54mm
  place J1 135890 -102870 front 0
component TO_SOT_Packages_THT:TO-92_Molded_Narrow
  place Q1 163830 -101600 front 90
component Resistors_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P7.62mm_Horizontal
  place R1 147320 -102870 front 180
  place R2 157480 -105410 front 0
  place R3 147320 -105410 front 180
image Capacitors_THT:C_Rect_L7.0mm_W2.0mm_P5.00mm
  pin Round[A]Pad_1600_um 1 0 0
  pin Round[A]Pad_1600_um 2 5000 0
image Diodes_THT:D_DO-35_SOD27_P7.62mm_Horizontal
  pin Rect[A]Pad_1600x1600_um 1 0 0
  pin Oval[A]Pad_1600x1600_um 2 7620 0
image Socket_Strips:Socket_Strip_Straight_1x06_Pitch2.54mm
  pin Rect[A]Pad_1700x1700_um 1 0 0
  pin Oval[A]Pad_1700x1700_um 2 0 -2540
  pin Oval[A]Pad_1700x1700_um 3 0 -5080
  pin Oval[A]Pad_1700x1700_um 4 0 -7620
  pin Oval[A]Pad_1700x1700_um 5 0 -10160
  pin Oval[A]Pad_1700x1700_um 6 0 -12700
image TO_SOT_Packages_THT:TO-92_Molded_Narrow
  pin Round[A]Pad_1000_um 2 1270 1270
  pin Round[A]Pad_1000_um 3 2540 0
  pin Rect[A]Pad_1000x1000_um 1 0 0
image Resistors_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P7.62mm_Horizontal
  net Net-(C1-Pad1)
    pins C1-1 D2-1 Q1-2 R2-1
  net Net-(C1-Pad2)
    pins C1-2 D1-2 D3-2 D4-2 D5-2 R3-1
  net Net-(D1-Pad1)
    pins D1-1 D2-2
  net Net-(D3-Pad1)
    pins D3-1 J1-3
  net Net-(D4-Pad1)
    pins D4-1 J1-4
  net Net-(D5-Pad1)
    pins D5-1 J1-5
  net Net-(J1-Pad1)
    pins J1-1 R1-2 R3-2
  net Net-(J1-Pad2)
    pins J1-2 Q1-3 R1-1
  net Earth
    pins J1-6 Q1-1 R2-2
Now I need to write code to link the "component/place" to the "image/pin" for positional information and  then decode "net/pins".
Update
I have bee a little bit distracted but back to it and have managed (though the use of associative arrays) to join the data:
  pin 1 0 0
  pin 2 5000 0
  pin 1 0 0
  pin 2 7620 0
  pin 1 0 0
  pin 2 7620 0
  pin 1 0 0
  pin 2 7620 0
  pin 1 0 0
  pin 2 7620 0
  pin 1 0 0
  pin 2 7620 0
  pin 1 0 0
  pin 2 0 -2540
  pin 3 0 -5080
  pin 4 0 -7620
  pin 5 0 -10160
  pin 6 0 -12700
  pin 2 1270 1270
  pin 3 2540 0
  pin 1 0 0
  pin 1 0 0
  pin 2 7620 0
  pin 1 0 0
  pin 2 7620 0
  pin 1 0 0
  pin 2 7620 0
Still more work to do.
AlanX
