GrowthCam
Plan growth monitor using an ESP32 camera and additional sensors.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The GrowthCam uses a ESP32 camera to make a timelapse of you plant and keep track of growth. It stores sensor data with the images to give you a way to traceback problems and learn from you plant development.
The device will be powered usin two AA NiHM batteries, there is a low power timer to turn of the complete device and the data will be uploaded only once in a while to get a decent battery life.
Images and sensor data will be stored to a micro SD card and uploaded
