floppy disk music on the go
Not a member? You should Sign Up.
Already have an account? Log In.
I designed a 3D printed case in FreeCAD for the disk drive, leaving space in the bottom of the case hopefully enough for a PCB and battery.
You can see the case files at - https://github.com/anfractuosity/turbodrive
Alas it did slightly split a bit when inserting the drive, so for the next print I'm going to increase the internal dimensions by around 2mm.
View project log
balintechnologies
Ryan Walmsley
Kyle Rector
Ricardo
Yes, delete it Cancel
You are about to report the project "Turbo Drive", please tell us the reason.
