A grain monitoring system that will cost about $500CAD (raw materials) instead of $4000 CAD. Also open source instead of closed source.
ds18b20_diagram.pdfschematic of ds18b20 cablesAdobe Portable Document Format - 35.31 kB - 08/28/2021 at 18:27 |
pcb_schematic.pdfthe schematic of the PCBAdobe Portable Document Format - 83.42 kB - 08/27/2021 at 15:50 |
Pinout-MKRsgm1400_latest.pdfPinout diagram of the MKR GSMAdobe Portable Document Format - 1.57 MB - 08/27/2021 at 15:49 |
I am just working towards getting some very nice instructions created and creating some instructional videos as well. I also still need to do some investigating on what resistor is best for each distance.
After reviewing my instructional video below I found that I also need to add a few things to the silkscreen and should consider making the board symetric.
The second PCB Revision was assembly and it is currently deployed and reporting the temperatures from 4 bins. Some things have been learned and have to improved again.
The two that come to mind are:
I think there is some PCB changes that I am forgetting to mention, but I will add them after I review my PCB assembly video.
First I should apologize about the lack of updates, and for my next project I intend to to logs more often.
The first iteration of this project is more or less completed. I am currently waiting for what I hope to be the final PCB design to arrive from Oshpark, and one of the earlier PCBs is connected to 3 bins that each have a cable and are reporting well.
At the moment it is just a monitoring system (no alerts) where current and past temperature data can be viewed on the Arduino cloud. I know when the project started it was going to be 100% alert based, but that changed when I realized how easy it was to launch things on the Arduino cloud.
The current monitoring is going well, except that some of my dad's peas were increasing in temperature drastically for a while, so it would seem that the design works well.
One thing that may have to be changed varying on deployments is the size of the pull-up resistor on the PCB board for the DS18B20 sensors. If too large a resistor is used on the long cables then the sensors will not read, and for one of my dad's bins this was the case for the standard 4.7K ohm resistor. In this case a smaller resistor needs to be used, and I will describe this in the instructions in more detail.
That brings me to the last major work that needs to be done ..... documentation. It is not my favourite part but it is very necessary, and I hope to have very descriptive documents for this project. The instructions on this project page will be how to build the device from scratch, but there will be other documents on the GitHub on how to build each part of the project separately. Also in the GitHub will be a document describing how to simply assemble the grain sensor with finished cables, an Arduino MKR board, and an assembled PCB board.
Of interest to some people might be that I plan to sell kits with all the disassembled components, as well as assembled monitoring cables and assembled PCB boards. The price for the disassembled components will be just above what I paid for them (enough to cover my time of packing it up), so maybe around $550 or so (all together separately the components are $500 or so). A kit with the cables and PCB assembled it will be about $1000 (I calculated this price roughly by paying myself $50 an hour). Both of these kits are to monitor four 5000 bushel bins. A wild card in the price is how spread out your bins are since if the two bins are close together and another two bins are further apart (like my dad's) they way it is set up now a lot more wire will be needed. In a different project log I will give a more updated explanation of pricing.
The price to run the system once it is assembled is the price of an Arduino IoT account, which for up to two devices is free, and the price of communication. When I was using the GSM Arduino the communication costs were about $10 CAD per month using hologram, but it will vary based on how often you want to report the temperature.
For anyone interested in this project please do not hesitate to contact me, or to express interest in purchasing the kits.
I have updated the instructions and the materials list. I know it needs a lot of work, and probably next weekend I'll add more detailed instructions and photos.
So the project has changed significantly since I last updated this page. I'll list the major news below:
The set up is currently collecting data from within a bin filled with canola. It is operating as expected, and I will continue to monitor the temperature variations so that I can best decide when a text alert should be sent out.
For the most part the project is done and working!
Later, could be awhile, I will give a more descriptive update and more in depth instructions of how to build.
Hey.
So I put the current build outside to see how long it would run for in the cold weather.
I did not do good. It sent me the first message but then six hours later (what I had set it to send the temperature at) there was silence.
I think it is a combination of the battery not being charged very much before and that the battery does not like the cold weather.
The next update will be switching gears a bit. I will be constructing a 40 foot usb cable to power the arduino off of (this will replace the solar panel and the battery), and then I will put it and the sensors into operation in an empty bin. This will be the first iteration of tests that will be done on a wired version.
The wired version is being further pursued at this point because it will be cheaper and will operate at the low temperatures better.
A bit off topic, but a contest where a friend and mine were going to present this project has been postponed till March or April.
Cheers,
Hey!
I have made an enclosure for the Arduino. Before this enclosure I just left the Arduino in a BBQ to see how long it would work on the solar panel. I also am using a more powerful solar panel. Right now I am mostly testing whether or not the poor battery will freeze in the cold even though it is inside an enclosure (does the Arduino dissipate enough power to keep it warm). My guess is it will freeze.
Cheers,
Hey!
I have the BinTempSensor inside the BBQ at home right now attached to a solar panel. Attaching a solar panel is an important step because it is needed to keep the project off the grid and able to be used in any bin.
It has been running for almost 3 days now and when it was running only on battery it only lasted two days at most. I have been checking it during the day and it seems to get fully charged (the battery) around noon each day. I would consider it a success.
The next steps are:
I am hoping to list step by step instructions to build the device to the point it is within the next week, but harvest and the new semester are starting so it may not be for a bit longer. For now the instructable I wrote a while back has the set up with the battery and I'll give a bit of a blurb below of how to extend it.
Instructable: https://www.instructables.com/id/Remote-Temperature-Sensing/
Next steps are:
Remember that the set up should be placed in a rain proof, but not water proof, enclosure to ensure that water does not mess things up.
Sorry for such a brief description I promise that within a month I will have better instructions (hopefully within a week!), but I thought it be good to give an update of where things are at.
Thanks for reading!
The cable schematic include in the files may help for this one, but it is nothing special
This is the order in which I would assemble the PCB.
The KiCad files can be found here: https://github.com/PhysicsUofRAUI/binTempSensor/tree/master/ecad.
I will be selling the bare PCBs as well as assembled PCBs on Tindie and possibly other places.
Also, I intend to improve these instructions greatly.
// OneWire - Version: Latest
#include <OneWire.h>
#include <DallasTemperature.h>
// On board Sensor
#include <DHT.h>
#include <DHT_U.h>
#include <Adafruit_Sensor.h>
#define DHTPIN A5
#define DHTTYPE DHT22
DHT_Unified dht(DHTPIN, DHTTYPE);
Sketch generated by the Arduino IoT Cloud Thing "DS018s_temp_test"
https://create.arduino.cc/cloud/things/952e3ad9-ef0f-46b0-aa63-a71ab33f7a11
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
float top;
float middle;
float bottom;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#define BIN_ONE_ONE_WIRE_BUS 13
#define BIN_TWO_ONE_WIRE_BUS 14
#define BIN_THREE_ONE_WIRE_BUS 5
#define BIN_FOUR_ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
// Bin One
OneWire binOneOneWire(BIN_ONE_ONE_WIRE_BUS);
DallasTemperature binOneSensors(&binOneOneWire);
DeviceAddress one_top_address = { };
DeviceAddress one_middle_address = { };
DeviceAddress one_bottom_address = { };
// Bin Two
OneWire binTwoOneWire(BIN_TWO_ONE_WIRE_BUS);
DallasTemperature binTwoSensors(&binTwoOneWire);
DeviceAddress two_top_address = { };
DeviceAddress two_middle_address = { };
DeviceAddress two_bottom_address = { };
// Bin Three
OneWire binThreeOneWire(BIN_THREE_ONE_WIRE_BUS);
DallasTemperature binThreeSensors(&binThreeOneWire);
DeviceAddress three_top_address = { };
DeviceAddress three_middle_address = { };
DeviceAddress three_bottom_address = { };
// Bin Four
OneWire binFourOneWire(BIN_FOUR_ONE_WIRE_BUS);
DallasTemperature binFourSensors(&binFourOneWire);
DeviceAddress four_top_address = {};
DeviceAddress four_middle_address = {};
DeviceAddress four_bottom_address = {};
unsigned long last_time;
void setup() {
// Initialize serial and wait for port to open:
Serial.begin(9600);
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// get the onboard sensor ready
dht.begin();
sensor_t sensor;
Getting Bin One's Sensors Ready
binOneSensors.begin();
if (!binOneSensors.getAddress(one_top_address, 0))
Serial.println("Unable to find address for Device 0");
delay(500);
if (!binOneSensors.getAddress(one_middle_address, 1))
Serial.println("Unable to find address for Device 1");
delay(500);
if (!binOneSensors.getAddress(one_bottom_address, 2))
Serial.println("Unable to find address for Device 2");
binOneSensors.setResolution(one_top_address, TEMPERATURE_PRECISION);
delay(500);
binOneSensors.setResolution(one_middle_address, TEMPERATURE_PRECISION);
delay(500);
binOneSensors.setResolution(one_bottom_address, TEMPERATURE_PRECISION);
Getting Bin Two's Sensors Ready
binTwoSensors.begin();
if (!binTwoSensors.getAddress(two_top_address, 0))
delay(500);
if (!binTwoSensors.getAddress(two_middle_address, 1))
delay(500);
if (!binTwoSensors.getAddress(two_bottom_address, 2))
binTwoSensors.setResolution(two_top_address, TEMPERATURE_PRECISION);
delay(500);
binTwoSensors.setResolution(two_middle_address, TEMPERATURE_PRECISION);
delay(500);
binTwoSensors.setResolution(two_bottom_address, TEMPERATURE_PRECISION);
Getting Bin Three's Sensors Ready
binThreeSensors.begin();
if (!binThreeSensors.getAddress(three_top_address, 0))
delay(500);
if (!binThreeSensors.getAddress(three_middle_address, 1))
delay(500);
if (!binThreeSensors.getAddress(three_bottom_address, 2))
binThreeSensors.setResolution(three_top_address, TEMPERATURE_PRECISION);
delay(500);
binThreeSensors.setResolution(three_middle_address, TEMPERATURE_PRECISION);
delay(500);
binThreeSensors.setResolution(three_bottom_address, TEMPERATURE_PRECISION);
Getting Bin Four's Sensors Ready
binFourSensors.begin();
if (!binFourSensors.getAddress(four_top_address, 0))
delay(500);
if (!binFourSensors.getAddress(four_middle_address, 1))
delay(500);
if (!binFourSensors.getAddress(four_bottom_address, 2))
binFourSensors.setResolution(four_top_address, TEMPERATURE_PRECISION);
delay(500);
binFourSensors.setResolution(four_middle_address, TEMPERATURE_PRECISION);
delay(500);
binFourSensors.setResolution(four_bottom_address, TEMPERATURE_PRECISION);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(4);
ArduinoCloud.printDebugInfo();
last_time = millis();
void loop() {
ArduinoCloud.update();
// Your code here
if (millis() - last_time > 600000)
// Get temperature from the pcb
sensors_event_t event;
dht.temperature().getEvent(&event);
if (isnan(event.temperature)) {
pcb_temp = -100.0;
else {
pcb_temp = event.temperature;
Get Bin One Temperatures
binOneSensors.requestTemperatures();
one_top = binOneSensors.getTempC(one_top_address);
if (one_top == DEVICE_DISCONNECTED_C)
one_top = -100;
Serial.println("Error");
one_middle = binOneSensors.getTempC(one_middle_address);
if (one_middle == DEVICE_DISCONNECTED_C)
one_middle = -100;
one_bottom = binOneSensors.getTempC(one_bottom_address);
if (one_bottom == DEVICE_DISCONNECTED_C)
one_bottom = -100;
Get Bin Two Temperatures
binTwoSensors.requestTemperatures();
two_top = binTwoSensors.getTempC(two_top_address);
if (two_top == DEVICE_DISCONNECTED_C)
two_top = -100;
two_middle = binTwoSensors.getTempC(two_middle_address);
if (two_middle == DEVICE_DISCONNECTED_C)
two_middle = -100;
two_bottom = binTwoSensors.getTempC(two_bottom_address);
if (two_bottom == DEVICE_DISCONNECTED_C)
two_bottom = -100;
Get Bin Three Temperatures
binThreeSensors.requestTemperatures();
three_top = binThreeSensors.getTempC(three_top_address);
if (three_top == DEVICE_DISCONNECTED_C)
three_top = -100;
three_middle = binThreeSensors.getTempC(three_middle_address);
if (three_middle == DEVICE_DISCONNECTED_C)
three_middle = -100;
three_bottom = binThreeSensors.getTempC(three_bottom_address);
if (three_bottom == DEVICE_DISCONNECTED_C)
three_bottom = -100;
Get Bin Four Temperatures
binFourSensors.requestTemperatures();
four_top = binFourSensors.getTempC(four_top_address);
if (four_top == DEVICE_DISCONNECTED_C)
four_top = -100;
four_middle = binFourSensors.getTempC(four_middle_address);
if (four_middle == DEVICE_DISCONNECTED_C)
four_middle = -100;
four_bottom = binFourSensors.getTempC(four_bottom_address);
if (four_bottom == DEVICE_DISCONNECTED_C)
four_bottom = -100;
The above code is the .ino part of the code, and the only edits that need to be made is the addition of your particular sensor addresses. Not adding the addresses will also work, but will probably have more unpredictable results.
Next is the thingProperties.h file where everything is configured. This file is automatically generated by Arduino if you are programming it through the browser.
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char THING_ID[] = "";
const char SSID[] = ""; // Network SSID (name)
const char PASS[] = ""; // Network password (use for WPA, or use as key for WEP)
float one_top;
float one_bottom;
float one_middle;
float pcb_temp;
float two_middle;
float two_top;
float two_bottom;
float three_top;
float three_middle;
float four_bottom;
float three_bottom;
float four_top;
float four_middle;
void initProperties(){
ArduinoCloud.setThingId(THING_ID);
ArduinoCloud.addProperty(one_top, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(one_bottom, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(one_middle, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(pcb_temp, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(two_middle, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(two_top, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(two_bottom, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(three_top, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(three_middle, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(four_bottom, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(three_bottom, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(four_top, READ, 900 * SECONDS, NULL);
ArduinoCloud.addProperty(four_middle, READ, 900 * SECONDS, NULL);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
This one is using the MKR WiFi, but any MKR device will work and Arduino Cloud will change the correct code if you are using a different device. The next step will show you how to configure the device/thing and that will take care of thingProperties.h so don't worry too much about it.
Thanks for your comment!
All the components combined cost $425.26 CAD for GSM, and about $50 cheaper if using MKR WiFi. The cheapest waterproof version of a DS18B20 I have found is around $10 CAD and for four bins 12 are needed, so $120 for all of them. MKR GSM is $100 CAD roughly, so now up to $220. Then a waterproof enclosure ($20 ish) and the PCB ($20 ish) I made to clean up the wiring, and it gets to $425.26. Then the wire has to be added, and that could vary if the bins are far apart. Eventually, I do want to make wireless communication between nodes to keep wiring costs down.
$500 CAD is an overestimate on my part since I am just calculating exactly what I have used in the current deployment and prefer to overestimate than underestimate.
$5000 CAD per bin is a quote that my uncle has gotten before. The cables of what is currently available come in at around $300 last time I looked. Honestly, I have not looked too closely at what is on the market since I already knew it was overpriced anyway.
Note: I edited this comment to change the component cost from $276 to $425 because I forgot to include the cost of the wire.
10 waterproof DS18B20 for $20 USD. No tax. Free shipping. Parts from China on ebay are so cheap I usually buy more than I need. Long delivery sometimes though. Wireless is the way to go where you can. I program the NodeMCUs wirelessly remotely as well using Arduino IDE. Far more convenient than plugging in. They have to be within WiFi range to do that. Free IFTTT will send an email alert if the temp is too high.
The NodeMCU serves a web page as an HMI locally or it's much easier to use Adafruit MQTT as an HMI from anywhere.
https://www.ebay.com/itm/114956606923?hash=item1ac3f29dcb:g:dawAAOSwaxFhKIpj
That is a good price. I normally get everything from Digikey.
This application cannot be completely wireless since it is collecting temperatures from inside a grain bin. Something has to hold the sensors in the middle of the bin (could be a rope if you do not need wire) unless you just drop them in while filling. If you do drop them in while filling I would write them off as disposable since when the bin is emptied they will probably be damaged.
The other problem of transmitting inside the bin is that when the bin is filled there will be grain all around the node and that will act like a very thick wall and will likely block most wireless transmission.
Also, it would have to have a fairly large battery to keep power throughout the winter while in the bin.
Here is a website of a place in Saskatoon offering slightly more affordable devices: https://adaptiveagriculture.ca/tempmoisture-cables.html
I don't see how the cost can be $500 let alone $5,000.
A $4 NodeMCU and a $2 DS18B20 and a few other inexpensive components can send temperature to a free MQTT HMI on Adafruit for display and recording visible from anywhere.
If the bins are not in WiFi range then ESP-NOW can send the data over 100 m to another NodeMCU that is on WiFi.
I guess if you must use GSM the above is not an option.
https://sites.google.com/site/nodemcu12e/home#h.bagvjtiwx7l3
https://hackaday.io/project/181289-esp-now-inexpensive-microcontroller-scada-system
