Operating in a bin
A project log for Bin Temperature Monitoring System
A grain monitoring system that will cost about $500CAD (raw materials) instead of $4000 CAD. Also open source instead of closed source.
kody-alan-rogersKody Alan Rogers 09/28/2020 at 17:360 Comments
The set up is currently collecting data from within a bin filled with canola. It is operating as expected, and I will continue to monitor the temperature variations so that I can best decide when a text alert should be sent out.
For the most part the project is done and working!
Later, could be awhile, I will give a more descriptive update and more in depth instructions of how to build.
