Finally, some progress!
A project log for BBQ Thermostat
A board-controlled temp probe and fan to maintain temperature during a long smoke or BBQ
ericeric 07/02/2022 at 18:540 Comments
On a whim the other day I stumbled upon the Adafruit page for the MCP9601. In there they mentioned trying to change the frequency of the I2C to 20k if not using SAMD. So I did and I was able to get the thermometer to work. Then I was baffled for a while on why I couldn't get the temperature to work if I put the motor board on. Turns out there was an I2C address conflict. I added a drop of solder to fix that and, viola! It would all work! I might publish a video some time in the future.
Now that this is working, I can FINALLY start to make this work for me.
Initial next steps:
  1. Get Wifi connecting
  2. Send temperature via MQTT
  3. Send Motor status via MQTT
  4. Figure out how to attach the fan to the smoker
  5. Develop a fan-speed to temperature algorithm
  6. Test algorithm without food
  7. Test algorithm with food
So excited!
