Hackaday.io Hackaday.io
Sign up Log in
Powerful DC Motor Driver [PWM-Half Bridge]
Powerful DC Motor Driver using Power Mosfets [30A, half Bridge]
hesammoshirihesam.moshiri
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
9 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
  • Hackaday Prize 2019
View Gallery
504
1
9
9
Team (1)
  • hesammoshirihesam.moshiri
Join this project's team
  • PCB Gerber Download/Order
ongoing project
2019hackadayprize DC motor driver PWm motor driver DC motor pwm mosfet driver IR2104 Mosfet motor driver power mosfet driver
This project is submitted for
  • Hackaday.com Tip Line
  • Connected World Contest
  • Beautiful Hardware
This project was created on 07/23/2019 and last updated 7 years ago.
Description
DC motors are everywhere, from hobby applications to robotics and industrial areas. Therefore there is wide usage and request for suitable and powerful DC motor drivers. In this article, we will learn to build one. You can control it using a Microcontroller, an Arduino, a Raspberry Pi or even a standalone PWM generator chip. By using a proper heatsink and cooling methods, this circuit can handle currents up to 30A.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
sara_queen wrote 07/23/2019 at 08:30 • point
Nice, I liked and subscribed to your YouTube channel also
I am using a board called the BeagleBoneAI-64 from Beagleboard.org for testing...
Project Owner Contributor
BeagleBoneAI-64 and Motors * 4
silver2rowsilver2row
Control DC motors with an Arduino, potentiometer, and MOSFET. Adjust speed and direction for versatile projects like robots or LEDs
Speed Controlling of DC Motor Using MOSFET
rithik-krisnarithik krisna
The DRV8243 is a highly integrated brushed DC motor driver IC from Texas Instruments, designed to deliver efficient, reliable, and compact m
Motor Driver Board using DRV8243
electronicsworkshopselectronicsworkshops
Hackaday Prize 2020
SOLO is a Motor Controller designed to easily run most types of electrical motors, DC, BLDC, PMSM and ACIM. it's easy to use and versatile.
SOLO, A Motor Controller for All Motors
miladmilad
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project " Powerful DC Motor Driver [PWM-Half Bridge]", please tell us the reason.
Send message
Remove Member
