Moving to BME680
A project log for Raspberry Pi recording thermometer
Indoor air quality (thermometer, humidity, pressure) sensor and dashboard
etienneEtienne 07/26/2019 at 04:240 Comments
I wasn't satisfied with the Enviro pHat:
Pimoroni just launched a new Enviro+ pHat, same format but with more sensors. It had a humidity sensor (great!) and other interesting sensing equipment, but also a microphone, which would be a big no-no privacy-wise.
I tried instead a BME680 breakout, with a pinout directly compatible with a Raspberry Pi. I still had to deport the sensor, otherwise the heat of the Pi would significantly bias the measurements (+5°C bias in my case).
