Hackaday.io Hackaday.io
Sign up Log in
Raspberry Pi 4 - GameBoy
Gameboy Pi made for music,not games.
fidel44jfidel44j
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.9k views
1 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
4.9k
1
1
1
Team (1)
  • fidel44jfidel44j
Join this project's team
hardware
ongoing project
This project was created on 07/27/2019 and last updated 7 years ago.
Description
Hello reader,first of all,i want to set the record straight. I´m a native Spanish speaker,i learned English as my second language entirely watching and reading internet stuff and with hip-hop. So,don´t be surprised if i cant express myself correctly. If you dont undeerstand something,i´ll try explaining it as best as i can on the comments. Let me get to the right rpm (33); My lovely asociate and funder,wanted me to make the handheld so she could make beats (music in general) i tought about adding a pro mic recording interface as well. Parts: - Raspberry Pi 4 - 2GB - SandDisk Extreme 32Gb - 2,8" LCD SPI Screen - Battery 3200/4200mAh - Battery Charger PCB Module - Gameboy Dmg Case - Button PCB Module- (Tindie) - Female Jack 3,5mm - Buttons - Heatsinks - Micro Fan Goals: - Portability - Easy to use - No Overheating (I had to make another account and republish,i wanted to add email to my gith created account and it bugge
Components
  • 1 × Raspberry Pi 4 2GB
  • 1 × 2,8" SPI ILI LCD
  • 1 × Gameboy Button PCB
  • 1 × 32GB U3 V30
  • 1 × Gameboy Case
View all 6 components
Project Logs
Collapse
  • Destroyed Pi4 - Surgery
    fidel44j • 08/02/2019 at 11:32 • 0 comments
    While triying to inset the Micro Sd Card after an eye accident with a pin from de LCD,I damaged a TSOP-23 Packaged device. Im pretty sure its a NA1G2.
  • Soldering The I/O Connector
    fidel44j • 08/02/2019 at 11:29 • 0 comments
    Im going to use the plastic female connector of an old computer IDE cable.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
BuckFuttit wrote 07/29/2020 at 03:21 • point
lookin good so far, I'm working on gameboy 4 as well. I had to remove my ports to fit im curious if you'll be able to make them fit with your build
The 2016 Hackaday Prize
Battery powered wireless UART Terminal for your Pi Zero(and others)
Project Owner Contributor
Blueberry Zero - Keep your Pi in your Pocket
sean-hodginsSean Hodgins
This is a DIY Raspberry Pi 3 gaming handheld running RetroPie to play all your classics!
Raspberry Pi 3 Gameboy
sotasystemssotasystems
Supplyframe DesignLab: 2022 Hackada…
A Raspberry Pi inside of a GameBoy retaining as much of the case as possible and using
Raspberry Pi Gameboy Utilizing Cartridges
daniel-johnsonDaniel Johnson
Hackaday Prize 2019
Portable Power Platform for Pi Zero
PiSugar Battery for Raspberry Pi zero
jdaieJdaie
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Raspberry Pi 4 - GameBoy ", please tell us the reason.
Send message
Remove Member
