Working on the code generator again
A project log for Targeting SDCC to the 8080
Writing a code generator for the 8080 microprocessor for Small Device C Compiler (SDCC)
ken-yapKen Yap 06/03/2020 at 16:010 Comments
After a long hiatus, I've found time to look at this again.
The first problem is still how to interface the builtin routines that do the right shifts that are too hard to do inline. The additional builtin routines expect inputs in particular register (pairs) and leave the output in a particular register (pair). However the code leading up to the call and after the call don't know this. It doesn't seem to be a matter of tellng the code generator we need those registers, it appears to be already decided at an earlier stage, as this dump of the code generated by the C statement
uchar0 = (uchar0<<1) | (uchar0>>7);
shows:
                            181 ;rotate4.c:28: uchar0 = (uchar0<<1) | (uchar0>>7);
                            182 ;ic:2:  iTemp0 [k3 lr3:4 so:0]{ ia0 a2p0 re0 rm0 nos0 ru0 dp0}{signed-char fixed}[a ] = (signed-char fixed)_uchar0 [k2 lr0:0 so:0]{ ia0 a2p0 re0 rm0 nos0 ru0 dp0}{unsigned-char fixed}
                            183 ;       genCast
                            184 ;fetchLitPair
   000F 21r05r00      [10]  185         ld      hl, #_uchar0
   0012 7E            [ 7]  186         ld      a, (hl)
                            187 ;ic:3:  iTemp1 [k4 lr4:6 so:0]{ ia0 a2p0 re0 rm0 nos0 ru0 dp0}{signed-char fixed}[a ] = iTemp0 [k3 lr3:4 so:0]{ ia0 a2p0 re0 rm0 nos0 ru0 dp0}{signed-char fixed}[a ] << 0x1 {signed-char literal}
                            188 ;       genLeftShift
   0013 87            [ 4]  189         add     a, a
                            190 ;ic:4:  iTemp2 [k5 lr5:6 so:0]{ ia0 a2p0 re0 rm0 nos0 ru0 dp0}{unsigned-char fixed}[c ] = _uchar0 [k2 lr0:0 so:0]{ ia0 a2p0 re0 rm0 nos0 ru0 dp0}{unsigned-char fixed} >> 0x7 {const-int literal}
                            191 ;       genI80RightShift
                            192 ; Dump of Right: type AOP_LIT size 2
                            193 ; Dump of Result: type AOP_REG size 1
                            194 ;        reg = c
                            195 ; Dump of Left: type AOP_HL size 1
                            196 ;fetchPairLong
                            197 ;fetchLitPair
   0014 21r05r00      [10]  198         ld      hl, #_uchar0
   0017 6E            [ 7]  199         ld      l, (hl)
   0018 26 00         [ 7]  200         ld      h, #0x00
                            201 ;fetchPairLong
                            202 ;fetchLitPair
   001A 01 07 00      [10]  203         ld      bc, #0x0007
   001D F5            [11]  204         push    af
   001E CDr00r00      [17]  205         call    sru1
   0021 F1            [10]  206         pop     af
                            207 ;ic:5:  _uchar0 [k2 lr0:0 so:0]{ ia1 a2p0 re0 rm0 nos0 ru0 dp0}{unsigned-char fixed} = iTemp1 [k4 lr4:6 so:0]{ ia0 a2p0 re0 rm0 nos0 ru0 dp0}{signed-char fixed}[a ] | iTemp2 [k5 lr5:6 so:0]{ ia0 a2p0 re0 rm0 nos0 ru0 dp0}{unsigned-char fixed}[c ]
                            208 ;       genOr
   0022 B1            [ 4]  209         or      a, c
Llines 187 and 190 show that the intermediate result of the left shift by 1 is left in A. My generated call to sru1() doesn't know any of this and leaves its result in HL, when the result is expected in C to be ORed with the previous A, which gets destroyed in the routine.
To understand how the SDCC register allocator works, I turned to the papers published by its author Philipp Klaus Krause. The first is Optimal Register Allocation in Polynomial Time. In Compiler Construction - 22nd International Conference, CC 2013, Volume 7791 of Lecture Notes in Computer Science, pages 1–20. Springer, 2013. Also of interest is Bytewise Register Allocation in SCOPES '15: Proceedings of the 18th International Workshop on Software and Compilers for Embedded Systems. They are quite heavy reading but the take away for me is that the register allocator has to know the costs and requirements of my right shift routines that fill deficiencies in the 8080 instruction set. One idea would be to look at how specialsed instructions like mult that have no alternatives and only work with particular registers are handled.
For some simple cases of shifting right by a literal, we can use the existing generation of inline assembler instructions. Then an issue is how to have different allocation behaviour between the cheaper and more expensive cases.
At the same time I've updated the sources not pertinent to the 8080 to the most recent SVN version so as not to fall too far behind.
