Hackaday.io Hackaday.io
Sign up Log in
SX8634 Touch Sensor Breakout
Can I... Can I touch it?
j-ian-lindsayJ. Ian Lindsay
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
5 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 5
View Gallery
Public Chat
874
5
2
4
Team (1)
  • j-ian-lindsayJ. Ian Lindsay
Join this project's team
  • KiCAD source files
completed project
touch breakout
Related lists
Tindie Breakouts
A list of breakout boards that I have listed on Tindie.
This project was created on 07/31/2019 and last updated 5 years ago.
Description
The SX8634 is an i2c capacitive touch sensor with slider support, flexible GPIO pins, and non-volatile configuration storage. As with most such sensors, circuit board layout is a special consideration. So I wanted to do it once, do it well, and be done with it for many hand-held projects to come. This board was designed to use the default configuration of the SX8634, but there is a demo program in the repo for writing the NVM.
Components
  • 1 × SX8634 Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
Project Logs
Collapse
  • Good things always die too early
    J. Ian Lindsay • 05/05/2021 at 15:46 • 0 comments
    Driver support will continue.
  • 2020.02.09: Video of board in action
    J. Ian Lindsay • 02/10/2020 at 04:51 • 0 comments
    I finally got around to shooting some video of a project using this board.
  • 2019.09.29: Arduino driver is working
    J. Ian Lindsay • 09/29/2019 at 08:27 • 0 comments
    The synchronous conversion is complete. The only thing untested is the NVM burn feature.
  • 2019.09.12: Finished units are now available on Tindie
    J. Ian Lindsay • 09/12/2019 at 16:37 • 0 comments
    Post title says it all. :-)
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
arthurb wrote 08/04/2019 at 11:42 • point
Cool!
What about gerbers?)
J. Ian Lindsay wrote 08/10/2019 at 00:09 • point
Published kicad src last night. Gerber generation is easy from there.
https://github.com/jspark311/SX8634-Breakout
J. Ian Lindsay wrote 08/10/2019 at 00:46 • point
If you want to buy one, I was thinking of making this my inaugural offering on Tindie. But it would likely be faster to order it off Osh and hotplate it yourself.
The SX8634 is a bit pricey for what it does, relative to other similar parts from other vendors. But I have zero complaints with this part so far.
I've found no mistakes in the datasheet (which is clear and complete), and the board performs beautifully.
The only driver I have written for it is for ManuvrOS. But an Arduino port wouldn't be difficult.
arthurb wrote 08/16/2019 at 21:50 • point
thx a lot!
J. Ian Lindsay wrote 08/17/2019 at 03:27 • point
You bet. :-)
Here is my fully-functional driver for the part. As I said, it isn't as easy as Arduino, and a port is probably forth-coming. But it should help you see what the thing can do.
https://github.com/Manuvr/ManuvrOS/tree/master/ManuvrOS/Drivers/SX8634
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SX8634 Touch Sensor Breakout", please tell us the reason.
Send message
Remove Member
