What is a precision amplifier?
Precision amplifiers generally refers to mechanical ones, such as low-noise high-precision amplifiers are usually used in medical electronic
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Precision amplifiers generally refers to mechanical ones, such as low-noise high-precision amplifiers are usually used in medical electronics, measuring instruments, automotive electronics, industrial automation equipment and other fields.
What’s more, the performance of high-precision amplifiers keep pace with the times, and they continue to innovate toward lower voltage, current, noise, lower offset voltage, lower offset voltage drift, larger bandwidth, lower power consumption and higher voltage. Meanwhile, constantly innovating also caters to the ever-increasing design needs of our customers.
