To begin developing two-way communication, I will began with the example sketches. I have tried combining both Master and Slave example sketches into one but failed. To help me resolve this issue, I have reached out for help on Arduino and Espressif forums. While I wait for answers, I decided to explore more closely the advantages and disadvantages of using a pre-built mesh library, like Painless Mesh or ESP-MDF. Here's a snippet of code which I tried to use, but failed:
void setup()
Serial.begin(115200);
WiFi.mode(WIFI_MODE_APSTA);
// configure device AP mode
configDeviceAP();
// This is the mac address of the Slave in AP Mode
Serial.print("AP MAC: ");
Serial.println(WiFi.softAPmacAddress());
Serial.print("STA MAC: ");
Serial.println(WiFi.macAddress());
// Init ESPNow with a fallback logic
InitESPNow();
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info.
esp_now_register_recv_cb(OnDataRecv);
esp_now_register_send_cb(OnDataSent);
unsigned long nextManage;
void loop()
// In the loop we scan for slave
ScanForSlave();
// If Slave is found, it would be populate in `slave` variable
// We will check if `slave` is defined and then we proceed further
if (slave.channel == CHANNEL2)
{ // check if slave channel is defined
// `slave` is defined
// Add slave as peer if it has not been added already
bool isPaired = manageSlave();
nextManage = millis() + 10000;
while (isPaired)
if (packetRecieved)
packetRecieved = false;
// Send data to device
sendData();
unsigned long t = millis();
if (t > nextManage)
nextManage = t + 10000;
// pair success or already paired
Serial.println("Slave pair failed!");
}Fig. 23 - My first, failed attempt at a two-way ESP-NOW communication sketch.
David M.
