08/19/19 - Official ESP-IDF Mesh example into PlatformIO
A project log for My attempt at an ESP-NOW Mesh
Designing a custom mesh for sensors, home automation and remote controlling and using Espressif's ESP-NOW
David M.David M. 08/19/2019 at 23:202 Comments
I tried uploading the ESP-MESH Internal Communication Example through PlatformIO but I couldn't compile it due to several undefined variable errors.
Fig. 28 - I switched the framework from Arduino to espidf in platform.ini but I received errors when compiling.
After a few tries I realized that a few variables weren't assigned because they are supposed to be defined in the project configuration menu when using the official ESP-IDF toolkit. I followed the getting started guide and tried uploading it the old-fashioned way.
Fig. 29 - Project configuration menu
However, I would like to continue using PlatformIO due to its "Peek Definition" feature, so I instead define all of these variables at the top of the file:
Fig. 30 - Manual defining of the config variables without configuration menu.
joshua.vader wrote 02/27/2020 at 17:29 point
So after defining all of those IDF variables, you were able compile in PIO?
David M. wrote 02/28/2020 at 19:04 point
Yep
