Firmware update for USB disk mode
05/17/2021 at 09:33 • 0 commentsUSB disk mode function was updated so that data logger can stay connected both to multimeter and computer at the same time. USB disk with logged measurement files can be disconnected and reconnected using controls without unplugging and re-connecting tiny micro USB connector all the time. This allows to quickly read measurement logs and re-run measurement session again.
User manual file was updated to show new functionality.
Enclosure and device update
10/12/2020 at 16:43 • 0 commentsDevice now has user manual and enclosure got rubber boots so it stays still on table. Data loggers listed on Tindie come in superb quality black SLS printed enclosure.
Another video shows how data logger might be used.
3D model of the enclosure
06/20/2020 at 15:52 • 0 comments3D model and print of the enclosure for the device is ready. Small changes should be made but overall everything fits together nicely. One catch, though, is that ABS material used for print is quite translucent and backlight from LCD screen illuminates through the material. This could be fixed by using additional light blocking insert or making front part thicker and having less translucent material.
---------- more ----------![]()
Model was designed using FreeCAD and consists of two parts bolted together.
Data logger prototype demo
05/30/2020 at 07:15 • 0 commentsHere comes video that shows existing functionality of data logger prototype.
It shows how measurements logging works and how measurements data files can be opened by connecting data logger to PC as USB flash disk.
Measurements are logged in two modes. In “interval mode” data logging rate is set in seconds, this would be useful to capture some lengthy process. Measurements are requested at this interval. As described in previous post measurements might not be taken at that exact time. “Continuous mode” measurements run at the rate that depends on multimeter measurement mode. It is not possible to change that but by logging one measurement and skipping some known number of measurements it is possible to achieve somewhat stable and changeable measurements rate. This would work for capturing measurements of some fast changing process. In video it shows how measurements of 0.5 Hz sine wave signal can be captured this way.
Data logging works for dual mode measurements as well. It is shown in second part if the video. Dual mode measurements - logging changes to both voltage and current was main reason why I got interested in DM3058 multimeter.
It did take a while to get so far. There are, however, more issues to be fixed.
Rigol tech support (un)response
09/26/2019 at 04:14 • 0 commentsWhile testing measurement recording I realized it is not really possible to read data at exact short intervals using external triggering mode. Sampling rate for DM3058 ranges from 400 ms in SLOW reading rate to 8 ms in FAST reading rate. But in case of external triggering it does not mean that measurement is done exactly at external trigger pulse. It seems that sampling runs on its own internal clock and on external trigger pulse multimeter just returns value of measurement that it currently is sampling. But it does not correspond to exact time when trigger pulse was sent. It does not really matter for logging lengthy battery discharge curve every few seconds or so. But it seems not possible to accurately log measurements anywhere close to sampling rate of DM3058.
I decided that for short intervals I might try using use internal triggering mode of multimeter and read out measurements when they are ready. It is possible to set custom internal trigger period in the range from minimum sampling time up to 2000 ms. But as I found out internal trigger period of the multimeter is not accurate either, not at least on my device. In fact it does not trigger at exact interval that is set using menu or serial command. Measurement triggers at some other time period that most likely depends on internal software or hardware constraints. I tested it with measuring slowly changing sine wave voltage at various intervals and different measurement rate modes. Sine wave period was fixed to 2 seconds. By saving built in measurement history (up to 2000 readings on DM3058) to USB flash I examined voltage wave forms using excel graph. I checked how many measurements were taken over one full sine wave period. I found out that while some trigger interval settings were logged as expected, most of them did use some other interval value that did change with selected measurements mode.
---------- more ----------I though I would just post this to Rigol tech support helpdesk, as these settings are set according to user manual and description but they don’t seem to work for me. I did not have very high hopes for it but response was unexpectedly helpless – see screenshot below. I wonder if any one from Rigol did actually try to read my message or did Mr. Christian Rau just wrote it of as ‘solved’ without bothering himself. It is so ignorant and somewhat rude, that I found it amusing. They made my day.
Controls and pcb layout
08/09/2019 at 12:32 • 0 commentsHaving schematic seemingly working on breadboard it was time to move on to PCB. This required some decision on layout and controls for the device. Controls would be power on button, recessed firmware upgrade mode button next to USB connector and four controls next to LCD. One for starting and stopping data logging, other for changing trigger period and two more for up down for navigation where necessary. Main PCB would hold all elements and connector for LCD with its own PCB on top. Pig tail cable to serial port of muiltimeter would go on back of main PCB. With controls besides screen this sets form factor for device. Device would stand vertically on bottom edge. It seems that main controls might be operated single handed.
I opted for standard tact switches with silicone like material caps I sourced from eBay. Enclosure around this layout could be designed and 3D printed. Although it would be great to have front panel overlay it adds to expense and is separate part.
Initial version of PCB layout is complete, time will show if it has any flaws. Such PCB can as well be factory assembled with through-hole components soldered on later. Switches can be replaced with surface mount versions for later layouts. Everything will be done by hand soldering now.
LCD display for data logger device
08/05/2019 at 10:19 • 0 commentsData logger can function without a display, but I realized that having one will make it much more understandable and easier to use. I shopped around for small graphic LCD with white backlight and black text. What I got was Zolen ZLE12864A LCD module from eBay seller in China. Although units with these exact colors were not listed after some discussion I got what I was looking for. Seller was able to look up exact LCD module for me with 3.3V logic level voltage. There is decent datasheet with setup commands and dimensional drawing as well. It has ST7565P controller – although cheap it does not have any font memory built it. Size of PCB will most likely define size of data logger.
It did take some months to arrive as I did not pay for express shipping. Manufacturing looks very clean and nice. First impression of LCD itself was not so great, though. Regardless of tweaking it has some vertical and horizontal shadows around displayed text and appearance changes a bit depending on viewing angle. But after a while I got used to it. If they look somewhat cheap that’s because they are. I got five for just $6 per item. They will be good enough for initial data logger prototypes. Main bottleneck might be code space and memory needed to operate them.
Functional and data logging considerations
08/05/2019 at 10:05 • 0 commentsInitial development on data logger device started sometime by the end of last year. First steps were to test serial commands according to programming manual and see how they can be used. After some tweaking it seemed that correct way would be let data logger to trigger measurement, wait when it’s ready and issue command to read value. All measurements from multimeter are reported as numbers in scientific notation like 1,506540-E10 so that text string is uniform regardless of actual value. To have values meaningful in log files data logger should query active measurement mode as well. Fitting reasonable amount of data in 16-megabit SPI flash requires converting values to binary format. When mounted as USB mass storage logger would decode these records and present them as text files in file system. I had some knowledge on how FAT file system works, but had to do a good refresh. About the X-mass time I was thinking more about FAT entries and partition records that anything else. It was fun time though and I got it working. I was able to built virtual file system on the fly, as there is no real memory available for data in plain text format. It works not very fast, though.
So it looks that device should have some pig-tail connection to serial port on back of muiltimeter so it can be connected and removed as needed rather fast. I might use RJ45 connector for this. I don’t quite like that locking tab on RJ45 plug is prone to breaking but sockets, connectors and protective boots as well are readily available. I would need just 6 wires for connection. So called British Telecom telephone plug looks like a good choice, but solderable small sized PCB sockets for these are not widely available.
Early design decisions
08/01/2019 at 16:15 • 0 commentsFrom hardware viewpoint device would operate in two modes – first as serial console to DM3058 multimeter and then as USB mass storage device when connected to PC. Early on I decided to use Texas Instruments ® MSP430F55xx micro controller for this task as it has stable USB support in hardware and I had some experience playing around with USB devices on MSP430F5529 LaunchPad board. For data storage I would use SPI flash chip, then I would need RS232 transceiver and some input protection ICs. I wanted to use lowest spec devices still adequate for the task. Parts would be SMD but still suitable for hand soldering, except for switches and alike that would be though hole, at least for first prototype. I ended up choosing MSP430F5510 micro controller for which I could use nicely designed Olimex ® MSP430-T5510 development board and set up rest of schematic on a bread board. For data storage immediate choice was to use somewhat outdated but still available Atmel ® AT45DB161 16-megabit SPI flash IC. I would see where it all will take me. Renesas ® ICL3221 would serve as RS-232 transceiver for connecting to DM3058E serial port. It has single RX/TX pair instead of classic MAX232 dual driver and receiver arrangement. It is also a bit cheaper than other similar ICs and ICL3221E version has somewhat better ESD protection specs on RS232 pins.
Quite a lot of wiring. MSP430-T5510 development board can be seen in red and RS232 transceiver on breakout board. SPI data flash and EEPROM ics are hanging out on wires.
To clear any doubts I would not consider device I am working on as a hack of any sort. Serial port specification and data exchange protocol for DM3058E is readily available at Rigol ® website. I am also not affiliated with the company in any way except that I have bought DM3058E multimeter through their product clearance web site.
Krists
