The Moon V2
A project log for Rotating Moon Clock
A clock with a real rotating Moon.
sephendevosSephenDeVos 04/05/2017 at 06:150 Comments
Because the moon will be lit from the inside light has to pass through the material and black isn't the right color for that. Also i had a problem with the black inserts being a little of center causing the moon to wobble. So i made these parts which let light pass through and can be adjusted later by loosening te bolts.
Not welded to the sphere yet.
