Installing the back panel
A project log for Rotating Moon Clock
A clock with a real rotating Moon.
sephendevosSephenDeVos 08/20/2017 at 18:350 Comments
Installing the back panel a fiddly job because it's a little cramped  inside. The top row of buttons are (ltr) set/next, up, down and esc. the bottom row are daylight saving switch, time set potentiometer – because the clock works with UTC time you can adjust the time with the potentiometer to your local time – and the last switch on the row turns the full-moon light on or off.
