What are some semiconductor devices?
A semiconductor device is an electronic component in which electrical conductivity is between conductor and insulator, with the specific ele
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
And semiconductor devices mainly includes two terminals, three terminals and four terminal devices.
Diode (rectifier diode):Gunn diode, IMPATT diode, Laser diode, Zener diode, Schottky diode, PIN diode,Tunnel diode, Light-emitting diode, Photo transistor, Photocell, etc.
Three-terminal devices: Bipolar transistor, Field-effect transistor, Darlington transistor, Insulated-gate bipolar transistor, Unijunction transistor, Silicon-controlled rectifier, etc.
Four-terminal devices: Photo coupler (Optocoupler), Hall effect sensor (magnetic field sensor), etc. [From Quora]
http://www.58pcba.com/index.php?id=690
