Any Lead off detection expert here?
A project log for EyesDrive - Steering with eyes movement
An innovative, non-invasive, assistive Human Interface Device for ALS affected people based upon Electrooculography (EOG) technique.
federico-runcoFederico Runco 04/20/2020 at 22:202 Comments
Since the very beginning of the project I've been using the AD620 instrumentation amplifier from Analog Devices, it works very well, the only thing that's quite annoying is that it operates in single supply on voltages above around 5V, but it doesn't matter a lot at the moment.
The AFE (analog frontend, I'll be using this word a lot) is almost completed, the only thing that I require is a Lead off detection system, imagine if you're using a wheelchair controlled by the EyesDrive AFE and an electrode gets disconnected: the AFE amplifies random noise and the wheelchairs begins to go around randomly, possibly hurting the user.
So I've used what's called a DC Lead off detection system, it requires just 2 pull up resistors and two comparators: when an electrode gets disconnected, it pull's up the input pin: here the comparator will check the voltage and, if it is above a certain threshold, it will trigger the system doing an emergency stop.
The Lead off works, but when i put the resistor between the input pins of the AD620 and the V+ rail the amplifer begins to behave strange, it amplifies random noise and the EOG isn't present at all.
If anyone has any advice (even if you know a better chip, it could be actually the real problem), please tell me, it would be very helpful!
the_3d6 wrote 06/19/2020 at 22:50 point
The problem with pullup resistor here is that it should be really high comparing to the skin resistance. We got good results with 40MOhm pullups (4 resistors of 10M each). Possibly 10M alone would work already - but that requires calculations, it might pull signal out of the operating range. If you had schematics available it would be simpler to recommend something :)
Federico Runco wrote 08/22/2020 at 23:36 point
Thank you for the hint, I never used such a large value for pull up resistor, I should definitely try.
Btw I'm publishing the schematics by the end of next week (I'm redoing them in KiCad, Allegro isn't as loved in community)
