Sun Tracker 2 Revision 4 - Dedicated Project
A project log for SunTracker 2 Revision 3
A learning platform for optimizing solar systems energy output through alignment to our suns path across the sky.
FrankFrank 11/18/2019 at 10:380 Comments
After 3 months work, Suntracker 2 Revision 4 is now coming alive in its separate, dedicated project log at https://hackaday.io/project/168507-suntracker-2-revision-4. While still not completely done yet, the newer, bigger, more complex version is coming into the final stages of assembly, coding and integration. Thanks for following this project! Cheers, Frank.
