Design Log #2
A project log for Edulog System
Educational Analog Modules
Zach StrohmZach Strohm 09/23/2019 at 19:250 Comments
Hey everyone, I finally had some time to work on projects again, and reworked the Op-Amp explorer board. I changed the general layout to make it more intuitive for a beginner, the components are laid out on the board in representative locations from the schematic. There are now also test points, thanks to a suggestion made to me. This should allow for quick measurements from points in the circuit that were not accessible in the previous revision.
I do plan on ordering boards, and constructing this revision soon. Then, I will work on writing an assembly guide, and update the workbook. As always, feel free to contact me more suggestions and comments.
